inserting point onto graph
From the existing, unfinished code fragments, I am guessing cig wants to label all peaks in green and all valleys in a different colors. You would just repeat the same code for the valleys using a different color, then concatenate the two cursor arrays before writing to the cursor list property.
Message 11 of 14
(1,070 Views)
That's it exactly - I need to highlight the peaks & valleys in any one color.
Thanks for the help -  I need to clarify all this in my mind. One more question : I currently have a while loop setup where I vary some control parameters & observe the resulting peak points found.
I need for the cursor points to refresh at each loop iteration. Right now the cursors just accumulate. How can I reset the CursorList to an empty array of clusters ? It looks like this should be done inside the loop.
ak
Message 12 of 14
(1,065 Views)
Simply use my method as in the second picture. This generates the cursor list from scratch instead of re-using any existing cursors.
(I still think you should use a second and third plot instead of cursors, though. ;:)
Message 13 of 14
(1,061 Views)
I'm still using 7.1 so I can't see your code but since you wrote:
"That's it exactly - I need to highlight the peaks & valleys in any one color."
Have you looked at the example called 'Peak Detection and Display.vi'???  It uses the method Altenbach recommends (i.e. plot points), is interactive, and is quite a bit simpler to implement than the path you're taking.  If you've already gone down this route then...  Never mind.Smiley Indifferent
 (I never thought I would have a use for the "smileyindifferent" emoticon) Smiley Happy
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 14 of 14
(1,051 Views)
