install LabVIEW 2018
Hi Community,
I am installing LabVIEW 2018, but I get this message and can not continue, has anyone faced this issue!?
See please the attached Photo.
I get the same message when I try to install LabVIEW 2017 also!!
(2,949 Views)
Of the Top of my Head, it's just the NI-DAQ device drivers.
You will not need them unless You need to connect the actual develop an application for Hardware You're planning to use to Your developement PC.
If this is the case, You can press, decline support, download NI-DAQ from NI's website, and install the drivers afterwards.
LabVIEW will work with or without the drivers.
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
(2,934 Views)
That dialog is just asking where the device driver install is located.  When you installed LabVIEW, you probably left the "Device Drivers" set to the default of "Custom Install".  If you don't have the driver disk, then just decline the support.
(2,907 Views)
