install labview 2011 on debian
I want to try, if labview 2011 works on debian stable.
Has anyone experience with the installation on (officially not yet supportet) debian stable system?
Should i use checkinstall or alien?
Any hints for installation?
After some google-working i got the dvd mounted.
if it works fine on debian linux as client system i want to use it on some linux in the productive area too where i could use any other no-cost-linux.
I think scientific linux could be a good choice. What would you suggest?
kind regards,
JS
system: Win7 and debian stable
(6,628 Views)
installation on Debian should work but it is not officially supported by NI.
You could test it though, and I will be testing it as well.
I will keep you posted on that though. Stand by.
(6,592 Views)
i could not read the dvd until i mounted manual with:
sudo mount -t hfsplus /dev/sr0 /media/cdrom
It was hard to find the right installation script. Found no useful documentation about installation on linux.
script did not ask where to install!
i had to type Y sometimes. I saw messages, that visa failed to install.
"let" was not found
After all, LabView2011 appeared in the gnome menu and i could start it.
LabView2011 took 50% of startup time then the windows version.
I was glad about the speed, but there was a bug in the menu. I clicked on whats new? But nothing happened. CPU load showed no action.
(6,556 Views)
You can run the Install script that comes with the CD.. It installs to /usr/local
(6,541 Views)
Ok, I tried Installing LV 2010 on Debian via the install script and it worked:
login as root: su OR use sudo
cd /media/cdrom
sudo ./INSTALL
say Y (yes) to License agreement and choose y on the LabVIEW Components to install...
Be aware, that drivers will not work (like VISA or GPIB) and therefore you will get some errors (the ones with "let:"  you mentioned) because its not supported...
now it will be installed in the Applications /usr/local/natinst
in your debian applications menue will be a "Programming" catregory and LabVIEW will be right there... and executable... LabVIEW starts up and you are good to go...
for the VISA and GPIB drivers i cant offer a solution, but this Link might help
Instrument Control in Linux Tutorial
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YFvZCAW&l=en-US
see also:
https://www.ni.com/en/shop/linux.html
(6,538 Views)
