install toolkit
I have the latest reliese of Labview 14 sp1.  I did not install the VI analyzer toolkit when I installed the rest of the package.  I want to install it now but it appears to want to re-install everything to do that.  Is that what I have to do?  I just want to add the toolkit not wait another 3 hours for a full install.
(4,477 Views)
You can install just the toolkit.  Just deselect all of the other items.  Even then, the other installers will skip since their software is already installed so it will go fast.
(4,473 Views)
Thanks but if I choose to not install Labview it will not let me choose the toolkit by itself.
So you think it will know LV is already there and not try to re-install it making me have to get new codes....  No internet connection so it is always a pain.
Edit:  Never mind.  I was able to select just the toolkit by answering yes to the pop up window warning me of the dependent products.  Thanks
(4,467 Views)
Yes, the installer forces you to "install" LabVIEW if you install a toolkit that requires LabVIEW.  But when it goes to install LabVIEW and sees it is already there it does nothing.
(4,451 Views)
