installer problem - config files
Hi!
Somehow it seems that my USB and RunTime installer is borked, my application doesn't seem to read the ini-files anymore (uses vi.lib - config.llb). Which Additional Installer is required for this to work? I assumed RunTime 8.2 would be enough, it doesn't seem to be.
/Yamaeda
Qestit Systems
Certified-LabVIEW-Developer
(3,046 Views)
Hi Yamaeda
Borked you say? Love that term 🙂 What is the problem you are seeing? Could it be a path problem? I don't have 8.2 installed at the moment, but I last used config file VIs in an exe in 8.6 and if memory serves me right that ran fine with just the RTE. Will run a quick test in 2009 to see if I remember correctly.
Best Regards
David
NISW
(3,011 Views)
Hi again
Worked fine with 2009 SP1. I think I have 8.2 on another machine in the lab, if you are still having trouble let me know and I could have a go with an 8.2 bult application.
Best Regards
David
(2,995 Views)
