installing GOOP?
I downloaded GOOP from ni.com and installed it. It installed two llbs in C:\Program Files\National Instruments\LabVIEW 6\Project. But when I try to access the VIs in the llbs I get the error: "Resource not found. An error occurred loading VI 'GOOP Class Wizard.vi'. LabVIEW load error code 8: Could not load VI resource." Can anyone tell me why this is occurring?
(3,635 Views)
This error code is common when you try to load code written in LabVIEW 6.X using LabVIEW 5.X . Make sure that you are opening the VIs with LV 6 or make sure that you install GOOP for LV 5.X if you are using LV 5.X.
-Jim
(3,635 Views)
Thanks for the help.
-iceman
(3,635 Views)
Hi Jim Kring,
I have the same problem, so where can I get the LV5.1 Goop toolkit ?
Please help and thank you very much
(3,635 Views)
GOOP for LabVIEW 5.1
Windows
ftp://ftp.ni.com/support/labview/vis/windows/5.1/goop/goop.zip
Mac
ftp://ftp.ni.com/support/labview/vis/powermac/5.1/goop/goop.sit
(3,635 Views)
