installing xp on pxi 8106
     I have a PXI 8106 controller, I wanted to know the detailed procedure of installing windows XP on it. I tried searching but was not able to get a proper method. Please do tell me how i can do it?
(3,161 Views)
So I think this link could help you installing xp on your pxi 8106:
http://ae.natinst.com/public.nsf/web/searchinternal/f46c72d0d751ed838625727c00775bd6?OpenDocument
If you can't open the link please reply
regards
grroesis
(3,134 Views)
     Thanks a lot. The problem is that i can't open the link.
(3,129 Views)
Here you can choose the Hardware Driver you need:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/de/pg/1/sn/n8:7,ssnav:ndr/q/pxi%208106/
And this is an instruction how to install windows on pxi 810x series:
http://digital.ni.com/public.nsf/allkb/F46C72D0D751ED838625727C00775BD6?OpenDocument
grroesis
(3,126 Views)
i have seen this doc already. The doc had not much clarity on installing the windows xp, so i wanted to know how to do step by step
(3,115 Views)
This isn't in fact your pxi but you can use it as an orientation:
http://digital.ni.com/public.nsf/allkb/97BC7E1EDEFE268A86256C0F006D7977?OpenDocument
If this orientation isn't enough I can adapt this document to your pxi 810x. Certainly it will take a lot of time.
Regards
grroesis
(3,112 Views)
