instant help
I am trying to build instant help for some function buttons, that is, once mouse move to this button it will display some help massage regaring the functionality. Please give any clue to do it.
(3,474 Views)
Are you talking about tip strips- little messages that pop up when you hover over an item in the front panel?
Right click on a control, select Description and Tip , then enter text that you want to appear.
(3,468 Views)
Also go to the Tools, Options, Front Panel and make sure that the check box for "Show tip strips for ..." is checked.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,451 Views)
Yes, that would be a key setting
(3,442 Views)
