instrument alias
      I'm getting "The file name, Directory name,or volume label syntax is incorrrect" when I'm trying to open visaconf configuration settings.
kiranmayi
Message 31 of 43
(3,643 Views)
when do you get this error? When you try to open the file or after you make the modifications.
(try opening the file using notepad and make the required changes.)
thanks
Ravi.
Message 32 of 43
(3,632 Views)
when I'm trying to open the file using notepad
kiranmayi
Message 33 of 43
(3,625 Views)
Accepted by gpsrt
There are three ways to change the aliases:
1. In MAX, under Devices and Interfaces>>GPIB and give the name.
2. Locate the "visaconf.ini" file and change the contents.
C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa
3. In MAX, from the toolbar go to Tools » NI-VISA » VISA Options. Under VISA options window select "Aliases".
If none of the above work that means there is a problem with VISA installation. You can download VISA 4.5 and VISA Runtime Engine 4.5 from here
http://joule.ni.com/nidu/cds/view/p/id/1267/lang/en
http://joule.ni.com/nidu/cds/view/p/id/1269/lang/en
here's the link that explains VISA aliases in detail.
http://digital.ni.com/public.nsf/allkb/FF9EEE0B28569617862573210073B69F?OpenDocument
thanks
Ravi
Message 34 of 43
(3,621 Views)
I did what you said.Even then I'm not getting the alias name.see the attached ones.Instead of getting "vipull",I'm still getting "COM1".
kiranmayi
Message 35 of 43
(3,598 Views)
Sorry Ravi,
                    I didn't save it.yeah,now I'm getting
kiranmayi
Message 36 of 43
(3,597 Views)
     for serial port it is ok.But, When I connect instruments,in MAX it is giving out "No visa resources found".see tha attached pic
kiranmayi
Message 37 of 43
(3,573 Views)
kiranmayi
Dennis, I'm not getting any reply for the above postSmiley Sad
kiranmayi
Message 38 of 43
(3,538 Views)
what happened to this thread?Smiley SurprisedIs this thread closed?
kiranmayi
Message 39 of 43
(3,506 Views)
Hello Kiranmayi,
It'll be helpful if you could explain your problem in detail. Are you connecting a GPIB device and it doesn't appear in MAX? If so, then how are you connecting the device, and what are the versions of VISA runtime and MAX on your PC?
Sorry if you happen to have given this information out previously on this thread, but it's gotten a tad too long to follow 🙂
Vaibhav.
Message 40 of 43
(3,489 Views)
