instrument driver HP86060C
There's no reason for it to change because you're not telling it to change. By default, a graph starts at zero (t0) and increments by 1 (dt). All that you are reading back from the instrument is an array of Y values. If you wire a waveform data type to a graph, it will automatically change the x scale because a wavefrom data type contains t0 and dt information. You can programatically change t0 and dt by creating a waveform data type with the build waveform function. You can also modify the x-scale with a property node. Right click on the graph and select Create Property Node. Right click again and select Change to Write. Right click again and select Properties>X Scale Range. You can select minimum, maximum, increment, etc. You can use the value from the span control to set the range however you need.
Message 11 of 24
(1,878 Views)
P.M-
Is this better?
Message 12 of 24
(1,771 Views)
hello.. is this updated. can i ask a favor regarding the source code of the HP86060C in labview. i need a reference in programming. hope yopu can help me
Message 13 of 24
(1,456 Views)
hello can i ask for a soource of this HP86060C for my reference. please. its hard to find the source code of it in the interet. thankyou. hoping for your kind consideration
Message 14 of 24
(1,453 Views)
hello can i ask for a soource of this HP86060C for my reference. please. its hard to find the source code of it in the internet. thankyou. hoping for your kind consideration
@UofH wrote:
The HP86060C is not made anymore and has drivers for LabWindows. But I am trying to connect 3 instruments on Labview using GPIB and this is one of them.Please help
Message 15 of 24
(1,451 Views)
If you don't want to use the cvi driver with wrapper, you'll have to create your own code. At http://www.ni.com/downloads/instrument-drivers/ there are links to instrument control basics and how to write a driver.
Message 16 of 24
(1,436 Views)
hi. i'm beginner in labview and would like to study the program of Agilent HP86060C in labview using GPIB. can you help me to have .VI file. thanks
Message 17 of 24
(1,421 Views)
There is no VI. There is only the LabWindows/CVI driver which is written in C. The manual of the instrument will contain everything you need to learn how to program it. That is where you need to start.
Message 18 of 24
(1,408 Views)
okay thank you... is this the manual you are saying???
Message 19 of 24
(1,387 Views)
do you have the file you aresaying. may i have one.. thank you
Message 20 of 24
(1,385 Views)
