11-14-2006 01:40 PM
11-14-2006 04:00 PM
11-15-2006 03:46 AM
11-15-2006 01:29 PM
11-15-2006 01:30 PM
11-16-2006 01:56 AM
11-16-2006 02:10 AM
Driver CD´s are May 2006
and
Eval.Version LabView 8.20 came on CD 350778D-01
Thank you.
P. Clemens
11-21-2006 12:21 AM
Hello Laemmermann, (Name is correct?)
were the informations (concerning origin and date of the drivers and LV Eval Version)
that I sent in my last reply helpful ?
My next try will be an installation on a "clean" XP-System to get LV running and trying the IIOA ,
but at the moment , there is none available .
P.Clemens
11-21-2006 01:52 AM
Hello beethoven,
please think about downloading the latest driver CD of this year (August 06) which is available from:
This is a rather huge file (~1 GB), so this is only useful if you have a broadband connection. In case I could also create a Service Request and sent these files on CD. In parallel I will setup a system with the same configuration (LV eval) for testing.
Please alternatively try to install the following files from the attached ZIP to the following location ('instrIOAsst' folder deeds to be created):
\LabVIEW 8.0\vi.lib\instrIOAsst
Unzip all of the files to the folder, start LV again and drop an IIOA VI on the blockdiagram.
Let me know if this works.
Otherwise post your email here and I will create a Service Request for you.
C.L.
11-21-2006 01:54 AM
