integartion
  A small clarification! I am using Labview 8.2. I am integrating data values from an array input. Actually the values of this array corresponds to a measured parameter 'rate of heat flow'. I wish to integrate it to get the values for 'cumulative heat production'. All the values are equally spaced (10 secs interval).
Sampling rate is 10 secs. I wish to integrate 6 data values  from array for each iteration i.e. interested to find cumulative heat value for every 1min duration.
My doubt is:
(1) Which integration VI I can use for this type of problem, integral x(t).vi (or) numerical integration.vi?
(2) What is the value for the increment dx (or) dt for my problem?
Senthil
(3,208 Views)
What are you clarifying? Is this a response to a thread you've already started? If so, post it in that thread instead of starting a new thread. There's literally hundreds of discussions going on in these forums. We can't keep track of every single one to know what you're referring to.
(3,200 Views)
Accepted by topic author 851624047
Let keep this all in one place.
(3,193 Views)
