integer to enumeration conversion - I'm being stupid
James, I understand the pain of forgetting to change a ring to an enum when dynamically populating the Strings - it's a very easy mistake to make. After making the mistake a few times, I resorted to populating the enum directly: it's much more error-proof. Check out my post here on how to populate the strings of an enum directly: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/convert-String-Array-to-Enum/idc-p/1025936 - (the code is in a For Loop since I have a Launcher VI that edits all the major typedefs).
Message 21 of 25
(1,254 Views)
The strings for enum can be written provided the VI owning the enum is not reserved to run or running. So if you write code to find the enum on the FP of a VI you can re-use that code to set the strings for enums and skip the ring completely.
Ben
Message 22 of 25
(1,249 Views)
Why not completly auto-generate the creation using scripting...
For example have a look at this tool in the Lava CR, there is a vi inside to create the states for a state machine (based on enum) that already completly does this. There is also some code that is doing search&replace operation enums.
Felix
Message 23 of 25
(1,244 Views)
Ben
- Presumably this is what Jack is using with his block diagram which I have to admit that I really don't understand 1 bit, I might understand it when I am allowed time to experiment with it.
Felix,
The reason why I haven't used scripting is that NI says that for assistance it is neccessary to go to R&D, Tech supportwon't be able to help, and they won't guarantee feature continutity of comapatibility between releases. (It is the second issue which keeps my company away from this, as there are currently only 2 of us doing the programming and if something is not guaranteed to work in the next release, we can't afford to spend the time debugging it.)
Great answers from 3 very good developers I respect alot. Thanks
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 24 of 25
(1,217 Views)
Been there, done that.
Off to make a suggestion on the idea exchange.....
Shane
Message 25 of 25
(1,200 Views)
