integrate a very sophisticated formula in labview
Hello all
in my Phd i have a very sophisticated formula that i need to integrate in my labview code .
please ho know a solution that can make easy this integration in my project
please see the example attached
(3,019 Views)
Accepted by topic author capitan_junior
You can enter it more or less straight from that text into a FORMULA NODE.
If you're interested in simplicity, that's the way to go.
If you're interested in better performance, you'll have to factor it, same as you would for any other language.
Instead of stating "2*pi*i*k" all those times, figure it once, and use it several times.
Steve Bird
Culverson.com
LinkedIn
(3,010 Views)
thanks a lot
(2,950 Views)
