integrating C++ in LabVIEW
Hi
I have written DLL for a for loop,imported in LabVIEW aswell but the program is not running(not counting) in LabVIEW
(3,271 Views)
Could provide a little more information? This isn't enough data to even begin making a guess. What are you trying to do? Development environments? Source code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,262 Views)
Thanks Mike
Actually I need to run the counting program in LabVIEW with the source of C++ program(imported into LabVIEW as dll)
C++ program is compiling successfully,the code
#include "stdafx.h"
#include <iostream.h>
#include <windows.h>
#include <conio.h>
BOOL APIENTRY DllMain( HANDLE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
    return TRUE;
_declspec (dllexport) int a (int counter)
  for (counter=1;
        counter<=1000;
     counter++)
  return counter;
Veera
(3,230 Views)
I think you have a bug in your C++ code.
You have the return clause inside the body of the loop which means that the loop does not do anything, it just returns the value of counter which is 1.
I guess you want something like this
  for (counter=1; counter<=1000; counter++)
     counter ++
  return counter;
By the way, why are you passing the counter as a parameter if it is given a value of 1 in any case?
(3,206 Views)
