integration of decaying acceleration signal
Hi
I have an experimental acceleration signal that is decaying with respect to time
I want to get velocity by integrating this signal. Practically the velocity signal should also decay with respect to time. But the integrated signal is not decaying ? Where am I making a mistake?
Corresponding VI and The AccelerationDATA is in the attached files.
Thanks in anticipation
(3,640 Views)
Hi
Sorry for inconvenience
Photo is attached herewith.
(3,639 Views)
Accepted by topic author Sehgal
Looks like you have some positive DC offset in the accel signal which then integrates into a velocity ramp.  A quick and dirty approximate solution would be to subtract off the best-fit straight line from the integrated velocity.
-Kevin P
(3,621 Views)
Or, as I just posted to the same question in the Signal Conditioning Board, subtract the mean before integrating.
Lynn
(3,618 Views)
I put a link to this thread in the other Board.  Let's keep the discussion here.
Lynn
(3,615 Views)
I think your mistake is your understanding of an integration 😉
If you accelerate something and stop the accelerating the item will stay at a constant velocity .....
If you want to include something like friction to get the velocity down to zero, I would add a 1 order highpass filter ... and put the timeconstant somewhere in the seconds rage ...
Greetings from Germany
Henrik
LV since v3.1
(3,586 Views)
Thanks Kevin
Using your technique I have solved the problem.
Thanks a lot
(3,582 Views)
