intensity graph exported excel data format
I've created a vi to acquire the peak-to-peak voltage measured from my oscilloscope and display it using the inensity graph. I can save the raw waveform data but I found that you can export the intensity graph data into excel. The only problem with this data is that the format isn't what I need. It seems to round the peak-to-peak voltage up for any value above 1 and for any value less than 1 it puts in in the following format 350m. I'd like the data to be displayed in decimal format to some nth significant digit. Is this possible? I've attached my exported data file.
Lowski
(3,121 Views)
I've never had good luck with the Export to Excel. Try using the Report Generation Toolkit instead.
Also, since you're trying to store waveform data, you might want to consider using a TDMS file. There's a viewer built right into LabVIEW in the TDMS pallet. All you need to do is wire in the path to the file and the viewer will open.
(3,119 Views)
Sorry it's taken me a while to reply but I figured it out. It turns out that my property settings for my intensity graph were set incorrectly for my application. I ended up deleting the graph and just creating a new intensity graph and it's worked great since then. I appreciate your help!
(3,035 Views)
