intensity graph
How can i get my intensity graph to show the data of each electrode in a 9x9 array? I need to be able to see which box is which.
Message 1 of 18
(5,698 Views)
   See the attached screenshot. Is this what you're trying to do?
Message 2 of 18
(5,690 Views)
Not quite its kind of hard to explain. I guess Im asking is there a way that i can split the 9x9 array up with spaces on the graph.
Message 3 of 18
(5,683 Views)
  • You can initialize an oversized 2D array with e.g. all zeroes, then use "replace array subset" to substitute your 9x9 arrays at the desired locations.
  • You can place an intensity graph inside a cluster, then place it inside a 2D array container and resize the array for 9x9 elements. Hide the borders and decorations of the graphs.
  • You could use a 9x9 array of pictures instead.
Message 4 of 18
(5,676 Views)
Are you trying to do this?
Message 5 of 18
(5,661 Views)
Yes but a perfect 9x9 square would be even better
Message 6 of 18
(5,656 Views)
There are two sub-vi's missing in your original attachment: calcder and rearrange. Can you post them?
Message 7 of 18
(5,651 Views)
Sorry I'm not at the computer where they are I can tomorrow
Message 8 of 18
(5,646 Views)
there are the two missing vis
Message 9 of 18
(5,603 Views)
I dont know how to do any of this.
Message 10 of 18
(5,586 Views)
