Showing results forĀ
Search instead forĀ
Did you mean:Ā
intensity graph
hi.
i use intesity graph to display captured images from my webcam. but the images are black and white in it. how can i display the images with their colors?
the other question is all webcams have some resolutions such as 320*240, 640*480, ... and the default in most of them is 320*240. how can i change the resolution in labview?
thanks
ali s.mootab
(4,399 Views)
Hello ali,
to change the colors: the intensity graph has a property node called 'colormap' (or similar, I have no LV at hand).
What resolution do you want to change: the resolution of your webcam (look into the manual and check if there are any software control commands) or the resolution of your intensity graph (just set the x&y-axis to the correct values or use autoscaling)?
(4,388 Views)
Hi GerdW.
Thanks for your attention.
For the first I try to find.
For the second I want to change the resolution of captured image from webcam, not Intensity Graph. But excuse me did you think you're wrong. I use 'capwind.dll' to capture images from webcam. I think I have to find a dll like this to change the resolution of the webcam in the registry or maybe in its driver that is installed. I think the software that is with the webcam do some like this.
Ali S.Mootab
(4,374 Views)
Hello Ali,
your 'capwind.dll' surely belongs to the webcam software/driver. So you should contact the guys from that company to give you advice!
If you have luck in writing your own driver for your webcam, it's maybe a good idea to give this to NI to incorporate in their instrument driver library šŸ™‚
(4,371 Views)
Hi GerdW,
I'll attache my program for you. I like it very much! you can use it to capture image from your webcam if you have. But images will be displayed just with its blue components. I want to display it colorfully. Can you help me?
If you extract it you will see capwin.dll.
Thanks.
Ali S.Mootab
(4,357 Views)
Hi GerdW,
I found it. There is a ColorTable property node for Intensity Graph. This is an array of 256 elements with RRGGBB format. You have to initialize this ColorTable property node and I think the Intensity Graph uses this table for a list of colors. Is there any default color table for this reason that contains all colors?
Ali S.Mootab
(4,354 Views)
