intensity plot
hi
i have one data file and i want to plot that data in intensity plot
the data which i have atteched here are looking same as in photo which i have atteched
so i want to plot that data and should match with photo
thanks
(4,080 Views)
I searched for intesity plots examples and explanation, and found something that can be useful.
Check the Intensity Graphs and Charts in the Types of Graphs and Charts help article, to see if you want to use a graph or chart.
Then, I strongly recommend you to take a look at the Intensity Graph and Chart Example.vi, which can be found by searching for "intensity" in the option menu Help >> Find Examples.
See what you can do with these information.
Best regards
Mondoni
(4,073 Views)
Hello
I had seen this article a month ago but still not getting any fruitful output from this
any other suggestion please
thanks
(4,041 Views)
Hi kabariya,
when you need the same result as in your JPG you should use the very same data. Or you should atleast know more about your existing dataset...
- Your "XLS" file is a simple text file. Don't rename it without a good reason!
- The file contains two columns of data, but they don't seem similar to your JPG...
(4,036 Views)
Accepted by topic author kabariya
kabariya wanted to continue with a double post here...
(4,014 Views)
