interactive execution mode in FPGA
islamabad,
I am not sure you can run the host to FPGA methods while the FPGA is running without throwing an error.  I will do some more researching though as to how  you can accomplish it.
Can anyone on the board confirm this hypothesis?
Daniel
Message 11 of 13
(1,344 Views)
Dear officer,
Hi! I have read these messages as I have met the same problem when I try to interface FPGA through C code,and the error-61203 appears.Would you mind if you can give me some instructions on this?
Thanks a lot!
Sincerely,
John
Message 12 of 13
(1,282 Views)
Could you explain in more detail which problems you are running into when trying to interface a C API with your FPGA? Unfortunately, I did not see any information about the error, -61203, you mentioned.
Could you also explain what your application is trying to do? Thanks!
Cameron T
Message 13 of 13
(1,262 Views)
