interactive file path
I am developing a VI that need open an ASCII file. The whole VI is contained in a While loop, except the file path VI (otherwise, the user is continuously asked which file he wants to open ...), but I would like to be able to change the ASCII file I want to read while running. How can it be done?
Thanks a million.
(3,222 Views)
Accepted by topic author isaac.fr
Use STATE MACHINE. And you can have different states corresponding to:
1. Selecting a File
2. Reding File
3. Updating GUI
4. Blah Blah
5. Blah Blah
and last Exit state.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,219 Views)
See this.. Hope this will help..
As soon as file will change inside while loop you can perform the read operation
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,211 Views)
Hello Isaac,
I don't know if you have access to Self Paced Online Training, but this also might prove useful:
http://ni.com/self-paced-training
If you don't have an Active SSP, then the following pages will also prove to be useful:
https://learn.ni.com/learn/article/labview-tutorial (maybe too basic)
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,187 Views)
