interactive front panel
I want to create a interactive VI that allow me to "write in an indicator" (when clicking on that indicator). I cannot use the property node : indicator, because the Vi is running.
My solution up to now, is to put a control over the indicator and make it visible when I need it (check my vi). Is there a solution more "easier" ?
Labview 8.0
(3,455 Views)
You can also enable and disable controls so they appear to change the way they act. The thing to remember is that there are three enable/disable state:
0 = enabled
1 = disabled but not grayed out
2 = disabled and grayed out
In addition you can update the contents of controls programmatically using the value and val(sgnl) properties even when they are disabled. Likewise, I believe mouse events are still fired when clicking on a disabled control.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,446 Views)
Anybody have an other solution ?
Thanks to reply on my new User Name
(3,387 Views)
Possibly, but Mike's solutions are the simplest and most elegant - have a control instead of an indicator and disable it when the user can't use it (right click on the control or the terminal and select Create>>Property Node and select the Disabled property) or use a local variable.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
(3,380 Views)
Was there a palace coup? No, then you'd have become "recently_deposed_monarch_Doyon"... Must have been a peaceful abdication...
Smiley Very Happy
Mike...
LabVIEW Champion
(3,359 Views)
