interfacing keithley 2401 source meter via gpib to a labVIEW interface to keep reading voltage and current values
i need to interface a keithley 2401 source meter to labVIEW and read voltage and current values across a solar cell ,i wish to connect the source meter to the pc via gpib . how should i proceed on the labVIEW interface to do the same?
Message 1 of 9
(5,813 Views)
Start by downloading the LabVIEW driver for it.  There should be an example with the driver to do what you want.
Message 2 of 9
(5,792 Views)
This driver does not support the 2401. I am interested in doing something very similar.
Message 3 of 9
(5,564 Views)
I am suprise.  I used this driver two years ago specifically  for the 2401...
Message 4 of 9
(5,558 Views)
The driver does not support the following models: 2401, 2425, 2400-C, 2410-C, 2420-C, 2440-C, 2425-C, 2430-C, 2400-LV.
Best Regards,
National Instruments - Instrument Drivers/IVI Group
instrument.drivers@ni.com
Message 5 of 9
(5,549 Views)
The commands are the same for the 24XX series, but they only tested the 2400....
Message 6 of 9
(5,545 Views)
Hey, if downloading, installing, rebooting, debugging, uninstalling, repairing etc etc to get the software to work properly didn't take me have a week, I'd probably just try it out. I'm just navigating a path based on that email I received from NI driver support group that I pasted in my last comment, the forums I've read etc. In the end, I used the KI-488 driver supplied by Keithley. It is NI compatible. I've have been able to get it to perform some basic commands eg/ *IDN?, and will do some more testing today. I believe you had some success, and I'll let you know if I resort to using your advice. Thanks!
Message 7 of 9
(5,530 Views)
how to interface keithely 2400 with driver?i want to store the values automatically.
Message 8 of 9
(5,092 Views)
