interfacing playstation 2 joystick with LabView 8.6.1
I'm trying to interface a Playstation 2 joystick using this adapter
http://www.ebay.it/itm/New-Dual-PlayStation-2-USB-for-PS-2-PS2-PS3-Convertor-Adapter-/111182867243?p...
with LabVIEW 8.6.1, without no results ...
My system is running
LabVIEW 8.6.1
MAX 4.5
VISA 5.0.3
I've installed the factory driver for adapter, and it appears in device manager, as HID interface, but in MAX is listed only the Software item.
Someone can help me ?
Thanks in advance
Eugenio
(3,378 Views)
Accepted by topic author uge026
Hi uge,
what do you expect in MAX when that device installs as HID component? You also don't expect to see your keyboard or mouse visible in MAX device tree!
As I didn't read the manual of that device: when it installs as HID device you may be able to read it's input using the LV functions for keyboard/joystick access…
(3,370 Views)
Thanks for the answer,
tried to use the standard functions to read the controller. Used Query Input Devices.vi, and found out 2 controllers for joystick, but labview sees only 12 buttons on 15. Nothing more, I'm not able to communicate with the joystick.
Any idea ?
(3,349 Views)
U where right, tried with another joystick and works fine. The first seems to be broken ...
Thanks for help
(3,293 Views)
