intergrating labview and labsql
There are two problems here:
1. You appended your question to the end of a 5 year old thread that wasn't even about the same problem. You are **very** lucky anyone saw this.
2. There is a problem with the ADO connection string. What is the string that you are using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 16
(1,247 Views)
this is what is have for the connection string "DSN=myDB;".
Not sure what i should type in.
Message 12 of 16
(1,241 Views)
Go to http://www.connectionstrings.com and look up the string you should be using. The correct string will identify the driver to use, and where the database is located.
Mike...
LabVIEW Champion
Message 13 of 16
(1,234 Views)
Which reminds me, what kind of database are you using?
Mike...
LabVIEW Champion
Message 14 of 16
(1,232 Views)
Currently I am using microsoft access
Message 15 of 16
(1,208 Views)
can you please share me labsql
Message 16 of 16
(637 Views)
