interpolate exponential value
I want to interpolate exponential values from a 1D array.
BR
(3,744 Views)
You problaby need to be a bit more specific.
Maybe you could a linear interpolation on the log and take the exponent, for example.
To get a linearly interpolated value for a fractional array index, you would just use "interpolate 1D array" from the array palette.
(3,723 Views)
Hi dummies,
is this somehow related to your older thread? If so: don't create double posts!
You still aren't able to supply example data and formulas, as was requested before…
(3,707 Views)
