intrument specific error code -1300
I got an error code with hp6629A power supply. The error code is -1300: intrument specific error. what does error code in simple english. I am new to the labview. how do I fix it.. if anyone have any hint? thank in advance
(2,821 Views)
In the source indicator of the error out cluster in the VI that generates the error (I'm assuming 6629A Config Output), what is the text? It should have soemthing like "6629A Config Output-" and then something else. Knowing that would be a big help.
(2,821 Views)
