invalid help link while trying to build programm
I get the following message while trying to use the Build Specifications:
"The following files have links to help files that are invalid. Open the files and fix the help links.
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\Simulation\Utility\Impementation\SIM Time.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\Simulation\ContinuousLinear\Impementation\SIM Integrator.llb\SIM Integrator distributor (for core)(vector).vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\Simulation\Utility\Impementation\SIM Reprot Error.vi"
Under Details the an error appers:
Error 7 occurred at ABAPI Check Help Files.vi --> ABAPI Dist Cmp Settings to Disk Hier.vi --> ABAPI Get Settings From File.vi --> SDBEP_Invoke_Build_Engine.vi --> SDBIP_Build_Invoke.vi --> SDBUIP_Build_Rule_Editor.vi --> SDBUIP_CreateNewWizard_Invoke.vi --> SDBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
Labview: File not found. The File might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. for example use \ as path separators on Windows, : on MAC OS and / on Linux.
NI-488: Non-existent board."
I have tryed to open the files and runned them with Shift+Ctrl, I allsow tryed to Mass Compile the files in the simulation folder. but this dosent seem to help.
I don't understand what I should do to fix the help files, anybody who knows?
The problem accures when I am using the VI Array Max & Min PtByPt.
Thanks for any help
-makaveli
Message 1 of 11
(5,503 Views)
Hello!
Please check out this link since it will most likely solve your issues.
What Do I Do When I Get an Invalid Help File Path Error?
http://digital.ni.com/public.nsf/websearch/1F25EBE7E7A07E91862571110080EA0E?OpenDocument
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
Message 2 of 11
(5,492 Views)
Hi Jimmie,
I am suffering the same problem discussed in this thread. However, when I try to see the link recommended for you I don't have access. It seems that is not working.
Could you help me please!!!!
Héctor.-
Message 3 of 11
(5,271 Views)
Hello Héctor!
The KB is archived but you can find the same information in the link below:
New document [link removed; article no longer available]
Hope this helps!
Jimmie Adolph
Message 4 of 11
(5,260 Views)
Hi Jimmie,
I have followed the indications from the link and I have solved my problem.
Thanks again,
Héctor.-
Message 5 of 11
(5,249 Views)
Hello Héctor!
Could you please be kind and mark my response as a solution to your problem? The ‘Kudos' button on the right in my response since it makes it easier for other people to find a solution to similar issues.
Thanks in advance!
Jimmie Adolph
Message 6 of 11
(5,244 Views)
Hi Jimmie,
Thanks for your answers. I already have marked in Kudos button.
Now, I have another doubt to solve. I am trying to stop a VI from another VI through VI Server feature. However, I do not want to stop the VI using abort method from VI Server. What I want is to set the value of a variable named stop which is wired to an ended element of a while loop in order to execute a piece of code before stopping the VI target. The problem that I have is that when the sampling period of the VI target is greater than 1seg (more and less), I see that the stop variable in VI target is pressed but the VI is not stopped. The state of execution of the VI target still is "Run top level" and no "Idel".
I have attached the VI target which is very simple "jilTest.vi".
Thanks in advance,
Héctor.-
Message 7 of 11
(5,218 Views)
Hello Héctor!
Look at the attached example that is a VI aimed to control the VI you posted here in this thread. Hope it helps!
Jimmie Adolph
Message 8 of 11
(5,203 Views)
Hi Jimmie,
Could you to attach the example to LabVIEW 8.2.1, please!!!.
Thanks in advance,
Héctor.-
Message 9 of 11
(5,200 Views)
Here you have the example saved in 8.2.
Jimmie Adolph
Message 10 of 11
(5,190 Views)
