inverse kinematics
i have a problem with inverse kinematics of a 3 DOF robotic arm. How can i take feed back from actuators?
(2,739 Views)
What is your problem exactly? You need to better specify your problem and even better, provide us with some of your current code illustrating the problem.
Marc Dubois
(2,699 Views)
I have a problem with the feed back's reading of the linear actuators. There is some vibration in the reading. is this due to the accuracy of the actuator? I use servocity linear acuator. can i solve this problem by some code?
(2,676 Views)
Not sure how this is a LabVIEW question....
Generally to solve noise problems (vibration) you average several reading over a period of time.
Another approach would be some kind of line fitting of the raw data.
A third approach would be pre-signal conditioning.
Hope this helps.
Former Certified LabVIEW Developer (CLD)
(2,669 Views)
