inverse on boolean condition
i mam new to labview and have come across a problem i cannot workout;
I require an inversion of boolean state on one line when the boolean state changes from false to true on another line.
Context: Voice triggered headlights (where other elements also have an effect on the headlights) the headlight turns ON/OFF upon the recognition of a voice command.
(3,588 Views)
BTW i think that it may use the 'Implies' function (but i am not sure) also i am using version 6.1
(3,587 Views)
Hello rkstokes,
yes "Implies" is nice to detect rising or falling edges of digital signals. You can connect the output of "Implies" to a "Select" (or a case structure) and use a negate function to switch on/off your headlight.
(3,583 Views)
Im still having trouble, i need an positive edge triggered latch idea.
on the attached VI i have identifyed the positive edge, i need some how to inverse line 1 on a rising edge in line 2, this inverse must latch till the next rising edge.
(3,566 Views)
Hello rkstokes,
that example should do it...
(3,556 Views)
