invert slide on system slide
I have strange problem with system slide.
I need to set max and min ranges on slide programmatically  like on this image:
I can't use flipped property node on that slide...
Any suggestions??
(3,112 Views)
you're almost there...you can implement a state machine programatically
(3,082 Views)
You could just compare the max and minimum and swap the values.
In the following video you can see how to do it.
http://screencast.com/t/XJsLbmcg8
I.R.
(3,060 Views)
Hi pawhan,
just swap the values for minimum and maximum:
(3,056 Views)
