invoke node: invalid method error
hi, can someone help me explain what i did wrong or help me try to solve these errors..
i am trying to work on an example problem and i dont see where i did wrong..
thanks in advance
labview 7.0
Message Edited by krispiekream on 03-14-2008 12:11 PM
Message Edited by krispiekream on 03-14-2008 12:15 PM
Krispiekream
Message 1 of 15
(5,328 Views)
I'm a little confused, because I'm pretty sure you can't insert a VI into a tab control.
I think that's the source of your error, but I have no idea how you got those invoke nodes to appear on the block diagram.
edit - I see what you did.  When you changed the example, you deleted the subpanels that were originally on each Tab page.  You have to insert the VI into a subpanel which is displayed on a tab page. (Subpanels are on the Control Palette under Containers)
Message Edited by JeffOverton on 03-14-2008 01:23 PM
Message 2 of 15
(5,322 Views)
okay, i didnt see the picture, i'll try that
Message Edited by krispiekream on 03-14-2008 12:23 PM
Krispiekream
Message 3 of 15
(5,316 Views)
There's not much to show, but I can explain the basics.  A tab control is nothing more than making the front panel kind of overlap itself.  All the tab pages are just front panel space folded like pages of a book.  A subpanel is used to display the front panel of another VI.  So you can put a subpanel on a tab page to show another VI, but there is no way to put another VI's front panel on a tab page.
Again, a tab control is just ordinary front panel space that you can only see a little of at a time, whereas a subpanel is another VI's front panel.
Message 4 of 15
(5,309 Views)
great!!!
thanks!!!!
Krispiekream
Message 5 of 15
(5,307 Views)
does it matter between a tab control and a dialog tab control?
Krispiekream
Message 6 of 15
(5,299 Views)
The dialog controls take their formatting from the OS, I think.  So the dialog tab control automatically uses windows colors, font, etc.  The tab control under containers is fully customizable.
Message 7 of 15
(5,296 Views)
for every tab, do i need to have subpanel?
or i only needed one..
i tried it..but it didnt come out..
when i run it, nothing show up on my subpanel
Krispiekream
Message 8 of 15
(5,292 Views)
if you want several VIs running simultaneously, and all showing up on separate pages, then you need several subpanels.  You will also need to open VI references to them, and run them via Invoke nodes (these are both under Application Control).
In the example I attached, first.vi and second.vi are inserted into separate subpanels, but only second.vi is run.  You can tell by running Tabs.vi and switching between the tabs that only the second has the boolean lit.
Message 9 of 15
(5,287 Views)
sorry, i have version 7.0 and 8.0
can you save it as 8.0 or something?
Krispiekream
Message 10 of 15
(5,285 Views)
