ip-address of remote machine (network streams)
hello,
i am using network streams to transfer data between a host and a client.
how can i obrain the ip-address of the remote machine?
best regards
(2,523 Views)
Probably you can't. You need a process running on the remote machine that actively provides the IP address.
Cheers
Edgar
(2,511 Views)
@labviewette wrote:
hello,
best regards
I use an approach modeled after how network printers are discovered. The server broadcasts its IP via UDP packets.
ben
(2,507 Views)
