ip integration node dependencies (LabView FPGA 2014)
Xl600,
Are you moving all of the files that are created from your IP Integration Node? I have tried moving the files after saving the project and when my project is unable to find the files it gives me the option to try to locate the missing files; do you get this option? In your last post you mentioned that you are opening your VI outside of your project; why are you opening it outside and not from the project?
One thing that I would recommend doing is creating a new project with a new IP Integration Node and put everything in a folder, then try moving the folder and see if it lets you search for it.
Scott B.
AE NI
Message 11 of 13
(1,204 Views)
I did not get a warning to try to find files.  I moved all files in the directory.  All files (The vi, the synthesis files, the generated files) are all in the same folder.
It also doesn't seem to matter if the enclosing VI is opened from within a project or outside a project.  The errors about missing VHD synthesis files is the same.
Message 12 of 13
(1,192 Views)
Did you have any luck with making a new project and a new IP Integration Node then trying to move it?
Scott B.
AE NI
Message 13 of 13
(1,181 Views)
