ipcam with labview by using videocap.ocx or videocapx.ocx
I have found two ocx, one is videocap.ocx,another is videocapx.ocx
two ocx can grab image from ipcam
could anyone do the above process by using  labview "ActiveX Container"
(4,675 Views)
Hello hsiaochung,
   關於在labview下使用ActiveX,您可以參考下面的文件說明
   ActiveX and LabVIEW: http://zone.ni.com/devzone/cda/tut/p/id/2983
   另外您也可以搜尋範例程式: LabVIEW>>Help>>Find Examples>>在Search頁面鍵入ActiveX
   裡面的範例就有關於ActiveX的使用,您可以從這邊開始著手
Alexander, NI Taiwan Engineer
(4,649 Views)
