is E4402B compatible with NI labview environment?
I'm using the agilent E4002B Spectrum Analyzer for my project, I'm required to program the Spectrum analyzer using Labview environment but I cant seem to communicate with the instrument. Any idea if it was compatible in the first place??  by the way, i used the agilent i'm connecting the instrument using the Agilent 82357A cable with the Agilent library I/O suite(Agilent connection expert).
Please help!!
(2,514 Views)
Your 'by the way' is probably the reason you are having problems. Enable tulip support in MAX for VISA and see if it works then.
There have been numerous posts on getting an agilent controller to work with LabVIEW. Do a search for '82357'.
(2,505 Views)
