is NI 9237 module compatible with Kulite ETM-375 Pressure Transducer
I am currently using NI cDAQ9189 DAQ system, NI 9237 module. is it compatible with my Kulite ETM-375 Pressure Transducer?
And I have External supply of 24Vdc, 25ma specification ignition system. So, can I use it for the configuration. Please let me know the configuration settings.
Hopefully, I will get a solution here.
Any solution/suggestion appreciated. Thanks.
Message 1 of 1
(926 Views)
