is VI developed in LAB VIEW on window will also run in labview on MAC ?
is VI developed in LAB VIEW on window will also run in labview on MAC without any change in VI model?
I mean is it compatible between windows and mac's lab view ?
Message 1 of 15
(3,405 Views)
Generally, VIs are compatible between platforms. However, there are some OS specific function that will not work everywhere. Do you use any DAQ?
What does your program do?
Message 2 of 15
(3,402 Views)
i m sending and receiving data using udp blocks in my model
Message 3 of 15
(3,400 Views)
Networking should work fine. What's a model?
Message 4 of 15
(3,395 Views)
model(i mean VI block diagram).
Message 5 of 15
(3,392 Views)
i m using pci-6025e DAQ card. can i send and recieve a digital pulse of 2 micro sec ? Can i use same pin for transmit and receive for this purpose ?
Message 6 of 15
(3,387 Views)
Did you look at the spec on your card? It can do 200KS/s, so your smallest pulse width will be 5usec. And I believe you can assign I/O as input or output programmatically as part of your task creation.
Message 7 of 15
(3,384 Views)
Is this a new question or is it still related to your MAC question? Driver support on the MAC is more limited. Start reading here.
Message 8 of 15
(3,380 Views)
OK for the time being i just want to do this:
i want to communicate with a system with 5us pulse using my PC
like if i want to send 11010100 then i will send
|----5US----|-------5US------|.............
____       ____                        _____                          _____
I      I___I       I_____________I         I______________I         I_______________________
|----1-----|-------1-------|------0-------|--------1--------|------0-------|---------1---------|------0-------|------0-------|
when i will send 11010100 to system the system will repond me by sending 10111001 usinf same 5us pulse as i have shown above.
I have pci-6025E+CB 50LP connector block+Cable and LABVIEW 10 installed in my PC.
Can this be done using NI's labview and PCI card ?
if yes then how ?
i m new to NI and this is my first Project using NI's hardware/software.
Message 9 of 15
(3,366 Views)
Once again, you can't get 2 usec with that card. For PCI, you would need one of the 625x series.
All the information you need is on the N.I. website, try it:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209160
Message 10 of 15
(3,358 Views)
