is it a bug or just a typo in Agilent 532XX Series\Public\Data\Low Level\Fetch Measurement (Single).vi?
Hi, All
I am using Agilent 532XX Series driver to read data from a frequency counter. In the low level subVi : \Public\Data\Low Level\Fetch Measurement (Single).vi, "Scan From String"  is used to convert the data.
however, if I check the error of this function, it always show me a error with current format string "%.;%g;". after I changed it to "%;%g", I don't get the error anymore.
If anyone use this funtion, please check the error out of that fuction and see what you get.
Regards
CQ
(2,989 Views)
I don't have the instrument, so I can't reproduce it completely, but I've done some research and if there is an error I don't think it's in the string conversion itself. I say this because:
From what I can gather, a typical output string would be the following: +4.27150000E-03
I took just a "scan from string" node and gave it that string as a string input and %.;%g; as the format specifier string. This yielded a numeric value of 0.0042715
So, as far as actually finding the root of the problem, there could be a few things going on. My first thought is some form corruption causing the data received to not be valid for conversion. There are two ways of testing this:
Open up a test panel in MAX and perform a loopback test, as described here: http://www.ni.com/white-paper/3450/en/#toc4
-or-
Install and open NI IO Trace and view the bus traffic as detailed here: http://digital.ni.com/public.nsf/allkb/282C5D41E2BA04F2862574BA007803B9
If the loopback tests works properly, go ahead and run the IO trace and post the results here.
(2,958 Views)
The period is there to force the conversion to use a period as the decimal separator instead of whatever the local setting is. Simple as that.
(2,953 Views)
Just in case you were wondering about any of the syntax in the format specifier string other than that period, this document explains it in detail:
http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/format_specifier_syntax/
(2,932 Views)
So, since the silly boys over at Agilent went and allowed the FORMat:DATA command. what you have is a bug and you should use this vi only when FORM:DATA? returns "ASCii,15"
Luckilly a *RST will put the device in that default condition.
(2,925 Views)
