is it a good idea to keep code clean with (huge) custom control?
well you can think of a cluster as a class of data. in your case you have only one big class. all subvis will have access to all that data. it is not only aestetically a problem, but also a hierarchy one:
instead of having sets of subvis for sets of clusters, allowing for very well defined folders per cluster in your project (plus "public" vis that would treat several clusters together), you might end up having all subvis getting all the cluster. it is then much more difficult to separate the subvis into categories. very fast, expanding development might become tremendously fastidious.
... And here's where I keep assorted lengths of wires...
Message 11 of 13
(453 Views)
Ok, I'll split the cluster and use several FG's. Thanks all for the input!
Message 12 of 13
(451 Views)
carefull with FG: use them, but dont abuse!
dont get me wrong, i love FG, but a healthy combination of normal subvis with FGs is still necessary, if you dont want the readability of the code to vanish. not to mention, one size doesnt fit all! 🙂
Good luck 🙂
Message 13 of 13
(447 Views)
