is it posible to create errorslist in one textfile
Hai to all,
Is it posible to create VI erroros in one textfile.
object.MassCompile(directory, [logFile], [appendLog], [viCacheSize], [reloadLVSBs])
what it menas:[logFile] and appendLog]
i want to complie VI from VBScript. and i want get the errors list in one text file.?????
thanks
sudheer
(2,567 Views)
Hi Sudheer,
you will find the answers to your questions in help from LabVIEW. Take a look in help Property and Method References>>VI Server>>Application>>Methods>>Mass Compile.
There you will find that LOGFILE "Specifies a file path where results of the mass compile should be placed. The default is no file." And for APPENDLOG you will find "Specifies whether results should be appended to the log file. The default is FALSE."
I hope this will help you.
Rebecca Fox
Rebecca Fox
(2,567 Views)
Hai,
Rebecca Fox
Thanks for your reply, i will try to...
sudheer
(2,567 Views)
Hai
Rebecca Fox
I got eroors text file, but i want to get flag value, i.e. if it has some errors on my LabVIEW program or directory(files),
i want to stop the process and i dont want to compile next programs. According to LabVIEW 7.0 MassCompile has no return value,
is it posible to return value ?
if it is not posible?
can i expect next version of LabVIEW.
Please give the solution any one also.
thanks to all and Rebecca Fox
sudheer
(2,567 Views)
