is it posible to get the iteration out of a subvi?
is it possible to get the actual iterationcycle of a forloop or whileloop out of a subvi into the vi?
how could i solve this problem?
Chris
(2,871 Views)
hi,
you have to take your whole loop out of the sub-vi and use only the code in your loop as a sub-vi, then you can access the iteration terminal. If your calling VI has a separate thread (i. e. execution doesn't wait for your sub-vi to finish), you can use a global variable to transport the information from your iteration terminal to your calling program.
hope this helps,
christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(2,859 Views)
Accepted by topic author OHC
This any good?
(2,848 Views)
Thanks to all
now it works!
its good to have the forum, someday i think i can give solutions also=)
Chris
(2,788 Views)
