is it possible to drive REXROTH pneumatic actuator which requires 24V & 500mA,, using LabVIEW ? if Yes, can anyone please guide me regarding the same ? I'm doing my project , so badly need info.
I'm doing project which requires pneumatic actuator. Available actuator in our college is REXROTH BOSCH pnuematic actuator. which requires 24V and 500mA drive. Also it has to be timing controlled (I mean it should be ON & OFF, software controlled)
I have attached snap of my LabVIEW block diagram. Here, comparator output has to drive Pneumatic actuator. Also we have NI 9485, 8 channel Solid State Relay (SSR), is it possible to use it in my project?
Thank you, your help is much appreciated...
(2,644 Views)
Please don't use the subject for your entire question.
That image has nothing to do with your question. It shows some vision capture.
(2,631 Views)
I apologize for my mistake,
I'm new to this community...
Image which I've tagged , contains 2 O/Ps from comparator.. I need to drive actuator from those O/Ps...
After processing Image & calculating number of particles, depending upon those numbers, i want to drive Actuator which i've specified earlier...
thank you for your time... help appreciated...
(2,618 Views)
Yes, you can use the 9485 to switch a 24 volt/500 ma source. You use DAQmx to turn s channel on or off.
(2,611 Views)
