is it possible to locate the CD or DVD drive
I was wondering whether it was possible to s it possible to locate the CD or DVD drive with Labview.
My application kinda needs to copy files off the cd drive onto the computer but i don't know how to locate the cd drive
thanks
(3,262 Views)
I'll add some more information about our problem.  We would like to detect if a particular drive letter is a CD or DVD drive.  The functionality should be similar to the following DriveInfo member in C#.
http://msdn.microsoft.com/en-us/library/system.io.driveinfo.drivetype.aspx
It can tell if a drive letter is a CDrom, Fixed, Network, Removable, Unknown, etc... drive.
I have searched the Advanced File VIs and Function for suitable functions and the GetVolumeData VI is very close (and we could probably detect drives with no free space).  However, I wonder if there are any other VIs that can help.
Another example is the following:
http://binaryworld.net/Main/CodeDetail.aspx?CodeId=917
Thanks in advance,
(3,246 Views)
Well, if you have a .NET solution that seems pretty easy. You can also try to find it by label rather than by drive, as shown in these examples.
EDIT: Or, you can use this little VI.
Message Edited by smercurio_fc on 11-14-2008 03:16 PM
(3,236 Views)
Someone also posted examples to the LAVA forums in the last few days (both .NET and calling the kernel API) to check the type of a drive.
___________________
Try to take over the world!
(3,207 Views)
Here:
http://forums.lavag.org/how-to-find-drive-letter-of-usb-memorystick-t12427.html
___________________
(3,203 Views)
I used the 'Get volume info' function to check the free space of the cd and it seems to work fine for now,
thanks
(3,074 Views)
