is it possible to use a file refnum as an input of mathscript node
Hi everybody,
I just began to use LV and mathscript recently. One problem confused me a lot.  That is,
Is it possible to use a file refnum as the input or output of mathscript node? A picture is attached for your reference.
Thanks a lot!
Gary
(2,708 Views)
Accepted by topic author garyleo
What would you hope to do with the reference?  The Mathscript node doesn't have a file reading capability.  You need to read the file and pass the data into the Mathscript node.
EDIT: I stand corrected.  You need to use the fopen and fclose functions inside of the MathScript node to be able to read a file inside of it.
(2,686 Views)
Hi Crossrulz, got it, So it means no corresponding data type of file refnum in mathsript, or to be converted.
Thanks for your support!
(2,663 Views)
