is it possible to use daqmx and traditional daq when both installed in the pc?
more pics
Message 11 of 20
(1,290 Views)
any answers??
Message 12 of 20
(1,275 Views)
The test method you show in your example works okay on my simulated IO card. I do not have a real one here for testing.
So, no answers so far.
Rob
Message 13 of 20
(1,262 Views)
how is it possible to simulate an IO card??
Message 14 of 20
(1,252 Views)
i get it now, you can do it when you have the DAQmx jeje
thanks for helping
Message 15 of 20
(1,251 Views)
In MAX you can add simulated devices, it can be very handy when you want to start developing your DAQ code before you receive your hardware.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 16 of 20
(1,249 Views)
Robert, you said it worked fine when you simulated it, im doing that too, but when i write ("low" 0) to port3, port1 must be at (high 1) but it's not responding in the simulation, can you tell me how you tested the code
thanks
Message 17 of 20
(1,239 Views)
has anyone tried to use the daqmx with a DIO6527?? besides robert and the other guys
Message 18 of 20
(1,219 Views)
thanks
What exactly are you simulating? There is no connection between what you output and what you read with a simulated device.
Message 19 of 20
(1,212 Views)
i've been  doing it with a real DIO, i have the port 3 connected to port 0 just to test if the lines are working good, when i write 0 at port 3 port one should read 1 and vice versa, but i get no response when i use the DAQmx, in the other hand if i use traditional DAQ it works very good. that's why i've been asking how can i work with DAQmx when using a DIO 6527 cause it seems it is not compatible
regards.
Message 20 of 20
(1,207 Views)
