is labview able to record the peak to peak value from an ECG wave automatically?
this is the waveform i am working on
Message 11 of 30
(1,239 Views)
can u tell me the name of the component that u use? thanx!
Message 12 of 30
(1,238 Views)
Under Waveform pallete > Analog Wfm >Measurements > Wfm Monitoring> Wfm Peak Detection vi
Labview user
Message 13 of 30
(1,224 Views)
i have another problem when i try to connect the initialize array to the array as shown in the pic. y am i getting that error? plz help >.<
Message 14 of 30
(1,221 Views)
It seems that you have placed array on front panel and not declared its type.
Try to do this.
Place an array on front panel. right click on fron panel and select numeric control or indicatior and place it inside array block.
Hope this will solve your problem.
Labview user
Message 15 of 30
(1,215 Views)
i dont understand how labview is working. is there any easy tutorial for a beginner?
Message 16 of 30
(1,214 Views)
You can see these links or  search for online tutorial. There are a no. of tutorials.
LabVIEW Basics II Course Manual
LabVIEWTM Basics II Development Course Manual
Labview user
Message 17 of 30
(1,212 Views)
thanx for the info! 🙂
Message 18 of 30
(1,210 Views)
Hi all,
Just want to make sure you realize the posted course manuals are very old versions - 1998.  The courses have actually changed names since then and are now called LabVIEW Core 1 and 2.  LabVIEW customers with an active SSP contract now have free access to video-based versions of the latest version of this content (plus corresponding exercises), and LabVIEW Full, Pro, and Developer Suite customers also receive access to LabVIEW Core 3 in this format.  To access the videos, make sure your software is registered to you and login with your ni.com user profile to http://ni.com/self-paced-training.
Message 19 of 30
(1,198 Views)
@Aojha wrote:
Here is an attachement.
Forgive my bluntness, but this is horrbile programming.  I've been following your solutions on here and, while your willingness to help is greatly appreciated, I would recommend refraining from posting until you understand the basic concepts of data flow.
Bill
CLD
(Mid-Level minion.)
Message 20 of 30
(1,195 Views)
