is optical drive available in labview?
are optical tools like EDFA, FP etalon,  isolator , circulator, coupler  available in labview driver? if so could you tell me the driver name and the procedure to install it.
(3,478 Views)
Hi sow,
usually someone has aa specific hardware and asks then for a LabVIEW driver.
Do you have specific hardware at hand? Can you name manufacturer, brand, type number, specification?
(3,458 Views)
HI GerdW,
am working on a simulation project of optical pressure sensor in Graphical programming language and so there is no need of any hardware. i want to know if there is optical tools/blocks.?
(3,446 Views)
@Sow2941995 wrote:
HI GerdW,
am working on a simulation project of optical pressure sensor [...]
That sounds more like a question for MultiSim.
LabVIEW (programming language "G') is a development environment to implement any kind of executable software code. There are functions for most common use-cases like matrix computations. There are tool kits providing extended functionality for specific use-cases like sound&vibration analysis.
I am not aware of an "optical sensor" tool kit as simulation of hardware is rather uncommon for LV applications. In most cases, as Gerd points out, developers are interested to control existing hardware to do specific measurment tasks......
Norbert
Norbert
Expert: Geometry
(3,440 Views)
