is tabbing through all the active cells of a table possible?
hi...
i need to tab through the active cells which are already not seen on the table. i mean i can only tab through the cells which i see, i need to use the horizontal scrollbar to move to the cells which are not already seen.
can i programmatically change this behaviour?
i used the example program below to disable a part of the table.
http://zone.ni.com/devzone/cda/epd/p/id/2163
then i noticed this behaviour. hope its the same with arrays also.
please reply with your valuable suggestions
thanks in advance
Renn
Kudos always welcome for helpful posts 🙂
Message 1 of 8
(3,837 Views)
Hi Renn,
you can use the event structure to react on the tab key. There you can use the property "top left cell" to scroll the table programmatically.
Mike
Message 2 of 8
(3,826 Views)
hi mike
i dont see this property. i'm using LV851. could you please send me a screenshot?
thanks
Message 3 of 8
(3,824 Views)
please see the attachment
Message 4 of 8
(3,814 Views)
Please hav a look at the VI
Message 5 of 8
(3,807 Views)
Hi Renn,
maybe the name has changed.
See the attached vi for the property a mean.
Mike
Message 6 of 8
(3,793 Views)
i hope the property ''Top Left Cell'' is of a digital table. couldn't find the same with a normal table.
Message Edited by RENN on 04-14-2009 03:53 AM
Message 7 of 8
(3,792 Views)
thanks mike
Message 8 of 8
(3,751 Views)
